Författare Ämne: Swebrick Brick Challenge (SBC) - Tidigare bitar  (läst 2207 gånger)
Utloggad Peter S
  • Global Moderator
  • Antal inlägg: 3 925
« skrivet: 09 maj, 2018 Kl:15.32 »
2018:
Augusti: "Bar 1 x 3 with Clip and Stud Receptacle (Robot Arm)" 4735
Juli:  "Panel 1 x 1 x 1 Corner" 6231
Juni: "Minifig, Utensil Radio" 19220
Maj: "Wedge 4 x 3 Open with Cutout and 4 Studs"47755
April:"Technic Knob Wheel" 32072
Mars:"Minifig, Footgear Flipper" 2599a
Februari:"Wedge 4 x 2 Sloped" 43721 och 43720
Januari:"Vehicle, Steering Stand 1 x 2 with Black Steering Wheel" 3829c01
2017:
December:"Slope, Curved 2 x 2 Lip, No Studs" 30602
November:"Plate, Modified 1 x 2 with Ladder" 4175
Oktober: "Bar 1L with Top Stud and 2 Side Studs" 92690
September: "Minifig, Utensil Frying Pan" 4528
Augusti: "Brick, Round 2 x 2 Dome Top" 553
Juli: "Tile, Modified 3 x 4 with 4 Studs in Center"88646
Juni: "Wheel 18mm D. x 14mm with Pin Hole, Fake Bolts and Shallow Spokes" 55981
Maj: "Technic, Pin 1/2 with 2L Bar Extension (Flick Missile)" 61184
April: "Tile, Modified 1 x 2 with Handle" 2432
Mars: "Brick, Modified 1 x 2 x 1 1/3 with Curved Top" 6091
Februari: "Plate, Modified 1 x 1 with Tooth Horizontal" 49668
« Senast ändrad: 08 augusti, 2018 Kl:16.02 av Peter S »
Inloggad Skafte
  • Betalande medlem 2020
  • Regionsansvarig Gotland
  • Antal inlägg: 5 012
SV: Swebrick Brick Challenge (SBC) - Tidigare bitar
« Svar #1 skrivet: 08 februari, 2019 Kl:09.14 »
Jag gillar den här tävlingen litegrann och har ibland nytta av den här sammanställningen. Kompletterar därför efterhand...
2019:
Oktober: ”Bar 1 x 3 with 2 Stud Receptacles (Radio Handle, Phone Handset)” 6190
September: "Minifigure, Plume Feather Triple Compact / Flame / Water" 64647
Augusti: "Brick, Modified 2 x 3 x 2/3 Two Studs, Wing End" 47456
Juli: "Slope 18 2 x 1 x 2/3 with 4 Slots" 61409
Juni:  "Brick, Arch 1 x 6 x 2" 3307 (eller varianter)
Maj: "Plate, Round 2 x 2 with Rounded Bottom (Boat Stud)" 2654
April: "Plant, Tree Palm Top" 2566
Mars: "Ice Cream Cone" 11610
Februari: "Chain 21 Links" 30104
Januari: "Plate, Modified 1 x 2 with Handle on Side - Free Ends" 2540
2018:
December: "Brick, Round 2 x 2 with Flutes (Grille) and Axle Hole" 92947
November: "Plate, Round 1 x 1 with Flower Edge" 33291
Oktober: "Appendage Bony Small with Bar" 15064
September:"Minifig, Cape Cloth, Standard" 522
« Senast ändrad: 09 oktober, 2019 Kl:20.08 av Skafte »
Utloggad Stigge72
  • Antal inlägg: 6 191
    • Min Flickr
« Svar #2 skrivet: 06 mars, 2019 Kl:17.58 »
Jag startade en sida i wikin om SBC (https://www.swebrick.se/wiki/index.php?title=Swebrick_Brick_Challenge), med tanken att alla bitar kunde listas där, kanske med en länk till den månadens tråd också?
Utloggad Stigge72
    • Min Flickr
« Svar #3 skrivet: 14 augusti, 2019 Kl:11.30 »
Av olika anledningar har det inte blivit så mycket skrivet på wiki-sidan, men nu finns lite bakgrund och en början (de första tre omgångarna) till tabell iallafall. Synpunkter på vilken information som skall finnas i tabellen?
Inloggad Magnus den store
  • Antal inlägg: 4 263
    • Flickr: Magnus the Great
« Svar #4 skrivet: 14 augusti, 2019 Kl:11.51 »
Det är nog inte så många som vet hur man skriver på Wikin. Jag tror att det är lagom information, men det finns två saker som saknas. En bild som visar biten istället för en länk till bilden, och tabell större separering. Bitnumret står exempelvis för nära månaden.
Utloggad Stigge72
    • Min Flickr
« Svar #5 skrivet: 14 augusti, 2019 Kl:16.06 »
Båda de sakerna är tänkta att vara precis som du skriver, men jag har inte lyckats hitta hur jag ska lösa det än. Den information jag hittat verkar gälla för wikipedia, som funkar nästan lika, och när det gäller vissa saker är det bara nästan.
Utloggad Teabox
  • Community Build Coordinator
  • Antal inlägg: 4 384
« Svar #6 skrivet: 14 augusti, 2019 Kl:16.33 »
Wikin vi använder oss av heter "MediaWiki". Hittar följande om att lägga in bilder på sidan.
https://www.mediawiki.org/wiki/Help:Images
https://www.mediawiki.org/wiki/Manual:Linked_images
Men det verkar som att vi (alltså en admin) måste slå på en inställning för att vi ska kunna länka till bilder på Bricklink. Alternativt lägga till Bricklink på en "white list".
Se:
https://www.mediawiki.org/wiki/Manual:$wgAllowExternalImages
https://www.mediawiki.org/wiki/Manual:$wgEnableImageWhitelist
https://webmasters.stackexchange.com/questions/74564/how-do-you-hot-link-an-external-image-from-a-media-wiki-site
Utloggad Stigge72
    • Min Flickr
« Svar #7 skrivet: 16 augusti, 2019 Kl:13.35 »
Se:
Jo, att ha bilden länkat till motsvarande BL-sida skulle ju vara smart. Borde iofs vara lättare fixat med numret...
Ska se om det finns några bra tabell-funktioner också, men inte exakt just nu.
